Home > Technical (L322) > Still not working! |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 |
I dont know what engine ye haiv.
30th Apr 2013 3:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
Bill, if you move your mouse over the little car under the avatar, it'll show what car/engine it is .. ... - .- -.
30th Apr 2013 3:21pm |
Sounds like your pump may not be getting sufficient power. That could be the ECU but also just wiring/fuses. Is there any way where you can measure the voltage going to the pump and see if that is stable.
30th Apr 2013 3:26pm |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
power the pump direct of the battery then try |
30th Apr 2013 3:41pm |
And measure voltage on the pump plug at the same time to see if it fluctuates. MY 2010 5.0 SC Galway green and sand interior!! Have the Faultmate MSV2 Extreme to be tinkering with the settings etc. !! |
30th Apr 2013 3:58pm |
RugbyXV Member Since: 14 Feb 2013 Location: Rugby Posts: 42 |
Thanks again all and especially Bill for your kind offer but I have a V8. I'll try the voltage stuff etc and see where we go. I'll update later this evening. Thanks again.. |
30th Apr 2013 4:28pm |
No probs.
30th Apr 2013 5:15pm |
Right, back in from the cave...
30th Apr 2013 7:18pm |
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 |
There must be something a diagnostic can pick up here? No fault codes reported, but did they check any live data readings? Also, which diagnostic system were they using?
30th Apr 2013 8:10pm |
I am considering buying the LYNX system that is being promoted in the LR magazines, has anyone tried this out at all? It's 250 pounds and is made by the outfit that write the T4 software and Britparts..
1st May 2013 7:19am |
