Home > In Car Electronics (L322) > Another Bluetooth issue |
Al Hornby Member Since: 19 Mar 2013 Location: Horsham West sussex Posts: 18 |
Hi Guy's
30th Apr 2013 3:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35427 |
i read somewhere that the venture cam might take 'priority' over the phone..i'm not familiar with your year but try disconnecting or taking the venture cam out.. ... - .- -.
30th Apr 2013 3:14pm |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
I had this after my BT upgrade from the same place. I have an 07 TDV8 VSE too, not that that should matter.
30th Apr 2013 4:19pm |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Had similar with my2005. First check plug on the bluetooth module for water damage Then i found that pairing and deleting the pairing a couple of times seemed to sort it.
30th Apr 2013 5:31pm |
Hi Chaps.
1st May 2013 12:09pm |
Which Phone and OS is the phone running on please as that could be a clue?
1st May 2013 1:00pm |
Hi Kingpleb.
1st May 2013 5:31pm |
No worries Al FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
2nd May 2013 10:38am |
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 |
Did you fix this? As mine had a similar problem which I fixed by changing a setting using the IID tool. |
13th May 2013 7:33pm |
Hi.
14th May 2013 7:15am |
Many thanks for the info. As I said I havent got an IID tool yet but I may see if I can get one at Billing this year if Britpart are there.
15th May 2013 1:19pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3847 |
I have this all the time, IPhone 4S, all I do is select the Off Road Screen and press the on screen Venture Cam Icon. Works every time except if I'm a little impatient and the screen will flash "phone disconnected" as it had already made the connection. If that happens I just press it again.
15th May 2013 1:49pm |
Hi Geoff.
15th May 2013 5:01pm |
