Home > Technical (L322) > Whining noise from front end TDV8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
before you go any further i would swop the wheels/tyres, it 'might' be the cause and obviously the cheaper solution... ... - .- -.
30th Apr 2013 7:24am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
An All Terrain pattern tyre will naturally produce more road noise than the standard road patterns, and this will change with road surface.
30th Apr 2013 7:42am |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
I might do this today...if it stops bloody raining!
30th Apr 2013 7:50am |
Right changed the wheels today....incredible, noise seems to have stopped.
3rd May 2013 4:06pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Hi can you confirm it was just them tyres then if you drove it more since last reporting.
4th May 2013 8:05am |
Sorry very disco, have not had a chance to take her out, plus not really wanting to use her with dodgy wheel bearing.
4th May 2013 10:36pm |
Ok, thanks
4th May 2013 10:44pm |
Very disco
5th May 2013 2:27pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8499 |
I have the grabber at's on one of our hilux, have the same noise from the front end, thought it was the wheel bearing, gave it a good going over and swapped the wheels over from the other hilux which has bridgestone duellers on. Noise disappeared. There is nothing that can't be fixed with a hammer😜😜
5th May 2013 2:43pm |
