![]() | Home > Technical (L322) > Coolant leak |
Dave ray Member Since: 19 Sep 2011 Location: Wirral Posts: 92 ![]() ![]() ![]() |
Loosing coolant where to look ? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Front of the car |
Gathered that after a bit of thought |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Coolant on the floor? Above the puddle if there is one. If not prob the rad as the fan will be blowing the coolant over a hot engine and evaporating. Where on the Wirral are you?
If its the front it's either; rad, water pump, hoses. If its never had a rad I would put money on that. New rads about £170 plus fitting. Quite easy if you can use a set of spanners. Hardiest part is gettin the viscous fan off. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Not to sure if its had a new rad only had the car 2 months its 2002 V8 I'm the second owner imactulate service history lots and lots spent on it did have td6 but had nothing but trouble with it. The v8 is miles better and the mpg is not a problem as dont do lot of miles and the V8 noice is the worth the 16.2 mpg |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
If it's waterpump then you'll see coolant on the front of the engine block, left hand side if looking from the front of the vehicle.
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
Your car is of a similar age to mine Dave - I replaced the expansion tank a few months ago as there was a hairline crack in the side of it. It's not a rare problem so might be worth looking closely at the tank as well. |
