Home > Maintenance & Mods (L322) > TDV8 winches |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35434 |
cant be fitted to the tdv8 as it puts the front axle over weight..
25th Apr 2013 9:36am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
. . . I must say, I've a soft spot for a FF with a winch
25th Apr 2013 9:44am |
madpugger Member Since: 07 Feb 2013 Location: Aberdeenshire Posts: 49 |
So the kit itself fits, but the issue is axle weight? If so, the weight issue can soon be overcome - and fitting a kit makes life a little easier than fabricating one! |
25th Apr 2013 9:52am |
seems it fits..i'd contact that dealer and have a chat.. ... - .- -.
25th Apr 2013 9:55am |
L322RR Member Since: 06 Oct 2011 Location: Düsseldorf Posts: 51 |
Hi,
26th Apr 2013 5:16am |
IIRC the frames do fit, and just require a slight mod due to a slightly different crossbar or something but nothing major and as for going over the weight limit, depends on how heavy your fitted winch is but most tend to go for warn, though hydraulic is also possible as well FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
26th Apr 2013 9:08am |
A FAKE winch?! How very dare you! Portable ones are ok, but I'd rather a front mount permanent one too. I'll likely fit a rear one also but that should be very easy... A hydraulic one would be nice, but are off the shelf pumps available for the tdv8 or would I need to make something work? |
26th Apr 2013 11:33am |
It would work off the power steering pump IIRC and not sure how easy it is to access that on the TDV8 but basically it gets plumbed into the circuit on the outlet of it. OTher than that uprate the battery to the standard 110ah one most for on here now and stick a nice AGM or such like in the boot to help provide some juice when needed but fuse it to 100amp to keep it safe
26th Apr 2013 11:37am |
