Home > Maintenance & Mods (L322) > TDV8 winches
madpugger
TDV8 winches
I am hoping someone can give some help here.
I am looking to get a TDV8 in the near future, but I want a winch on it. LR states their winch bracket is not for a TDV8, does anybody know why exactly that is, and if so what is the solution?
Has anyone fitted a winch to their TDV8 yet? Some picture or links to kits/solutions would be appreciated.
Thanks
Mike
Post #184647 25th Apr 2013 9:30am
cant be fitted to the tdv8 as it puts the front axle over weight..
http://www.devon4x4.com/products_a/c24/ind...;Itemid=14 ... - .- -.
Post #184649 25th Apr 2013 9:36am
TugRR
. . . I must say, I've a soft spot for a FF with a winch Whistle
I've never seen one in the flesh, though ?
Thumbs Up Where do you go after one of these . . . ?
Post #184650 25th Apr 2013 9:44am
madpugger
So the kit itself fits, but the issue is axle weight?
If so, the weight issue can soon be overcome - and fitting a kit makes life a little easier than fabricating one!
Post #184651 25th Apr 2013 9:52am
seems it fits..i'd contact that dealer and have a chat.. ... - .- -.
Post #184652 25th Apr 2013 9:55am
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
Hi,
I think the best solution is to buy a portable winch that fits on the tow ball, just plugs in the tow bar plug.
The good point is that you can take it with you when you sell the car.
In my small offroading experience, I think towing from the back will take you out of where you are stuck 80% of the time. If it's for leisure, just go around the obstacle.
if you like the look, just install a fake one.
Post #184808 26th Apr 2013 5:16am
IIRC the frames do fit, and just require a slight mod due to a slightly different crossbar or something but nothing major and as for going over the weight limit, depends on how heavy your fitted winch is but most tend to go for warn, though hydraulic is also possible as well Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #184860 26th Apr 2013 9:08am
madpugger
L322RR wrote:
Hi,
A FAKE winch?! How very dare you! Wink
Portable ones are ok, but I'd rather a front mount permanent one too. I'll likely fit a rear one also but that should be very easy...
A hydraulic one would be nice, but are off the shelf pumps available for the tdv8 or would I need to make something work?
Post #184890 26th Apr 2013 11:33am
It would work off the power steering pump IIRC and not sure how easy it is to access that on the TDV8 but basically it gets plumbed into the circuit on the outlet of it. OTher than that uprate the battery to the standard 110ah one most for on here now and stick a nice AGM or such like in the boot to help provide some juice when needed but fuse it to 100amp to keep it safe Smile
PS i have a tray and bits if needed just no winch Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #184892 26th Apr 2013 11:37am
