![]() | Home > Maintenance & Mods (L322) > battery charging |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
Due to doing a low mileage I've had to top up the battery using my Ctek charger, not a problem in the garage just a pain leaving the bonnet open and crocodile clips onto the battery.
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
I've always used trickle chargers and these can be plugged into the cigar lighter socket in the boot. 2009 Vogue TDV8 Nara Bronze
Martins adapter avoids either leaving a door or window open or clamping the cable in the door seal. This is what attracted me to it. |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
I stuck one of these in the rear side window of the FF and plugged it into the socket in the boot:
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 816 ![]() ![]() |
do you know with this charger connection, if you can apply a voltage to it when changing batteries so the FFRR does not lose supply at any point?
Yes you can.
