Home > Maintenance & Mods (L322) > battery charging |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 |
Due to doing a low mileage I've had to top up the battery using my Ctek charger, not a problem in the garage just a pain leaving the bonnet open and crocodile clips onto the battery.
22nd Apr 2013 7:05pm |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
I've always used trickle chargers and these can be plugged into the cigar lighter socket in the boot. 2009 Vogue TDV8 Nara Bronze
22nd Apr 2013 9:39pm |
Martins adapter avoids either leaving a door or window open or clamping the cable in the door seal. This is what attracted me to it. |
22nd Apr 2013 11:01pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
I stuck one of these in the rear side window of the FF and plugged it into the socket in the boot:
22nd Apr 2013 11:52pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 808 |
do you know with this charger connection, if you can apply a voltage to it when changing batteries so the FFRR does not lose supply at any point?
29th Apr 2013 7:08pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Yes you can.
29th Apr 2013 7:24pm |
