Home > Technical (L322) > How do you clean mud off the underside of the car?
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Well I went off-roading this weekend and had a great time. Unfortunately the FFRR is now caked in mud underneath and around the brakes and suspension. I tried a gentle pressure wash to get the worst off, but unfortunately the brakes are clogged and dragging a bit too.
Anyone got any tips to get rid of this, apart from sticking it in off-road mode and crawling underneath with a pressure washer / brush?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #182943 14th Apr 2013 8:44pm
mzplcg
Like this Mr. Green
Post #182945 14th Apr 2013 8:57pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Re: How do you clean mud off the underside of the car?
As far as im aware its either this or KLEENTEC, Which is great but massively expensive.
Post #182946 14th Apr 2013 8:58pm
Garden sprinkler works a treat. Thumbs Up
Just move it about to cover the whole car.
Post #182947 14th Apr 2013 9:00pm
most car washes do an underside wash...
nice pic Dom Thumbs Up ... - .- -.
Post #182949 14th Apr 2013 9:02pm
barracuda816
^ Worthless in my opinion, the one i have seen wont touch any real mud. At best they help rinse the salt off a little. 5 mins with a pressure washer is mile better.
Post #182950 14th Apr 2013 9:07pm
TheAllSeeingPie
We didn't have any clean water to get rid of the muck. Only streams filled with clay and occasionally cow dung. Was a hell of a day though and can't wait to do it again.
Post #182952 14th Apr 2013 9:12pm
One year I went to collect my son from T in the Park and the mud was so bad it coated everything underneath and it set like a cement like substance. It took hours with a pressure washer to shift it, hours. Doms picture is the way to do it, let it soak, then blast it off. Previously..
Post #182955 14th Apr 2013 9:27pm
£10 on a garden sprinkler and if its rock hard leave to soak in a little. Use the mist setting to soak and then the stronger one to wash off.
Tie the sprinkler to some long string as well and use that to pull it to and fro under the car Smile has kept mine ok after my trips.
I used to have to put my scruffs on, stick it in extended hieght as lay down at each side of the car and use the garden hose everytime but now it only gets that every few months Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #182967 14th Apr 2013 11:41pm
mzplcg
You were there mate if you recall.....Salisbury 2011
Post #182973 15th Apr 2013 5:48am
i know Mr. Green Wink ... - .- -.
Post #182977 15th Apr 2013 7:13am
Johnte
If you have a Karcher ...
http://www.karcher.co.uk/uk/Products/Home_...leaner.htm Whistle
Post #182983 15th Apr 2013 8:27am
that looks good Thumbs Up ... - .- -.
Post #182994 15th Apr 2013 9:03am
£65 off fleabay...
Though why not just get a patio cleaner, stick wheels on its top and use that for a lot less money and something that could scrub as well? On the l322 IMO your better off soaking with a hose and laying on your side so you can see whats being done. As that video shows it still left stuff on the rails even after a few passes... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #183001 15th Apr 2013 10:12am
mzplcg
kingpleb wrote:
Though why not just get a patio cleaner, stick wheels on its top and use that.
'Cos that's Redneck engineering, that's why KP Laughing
Post #183013 15th Apr 2013 10:58am
