Home > Technical (L322) > drivers electric window motor labouring
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi all
Car went for its MOT today and passed with flying colours but on the way there i opened the drivers window and the motor sounded like it was struggling to open same when i try and close it the motor sounds like its labouring and working too hard. Have taken the door card off to take a look and it all looks like, nothing happened to it just started randomly
Any ideas??
Matt
Post #182783 13th Apr 2013 5:24pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Ill start with the fourums fav, have you checked the battery voltage both when running and not?
Is it the only drivers side thats the problem?
Post #182796 13th Apr 2013 5:59pm
something in the window slide grooves ? ... - .- -.
Post #182799 13th Apr 2013 6:32pm
mattstevenson2005
the battery voltage is good its only the drivers side with the problem, i have sprayed some silicone fluid in the window grooves. it was my first idea just incase it was a little dry and was causing too much friction but doesn't appear to have helped.
matt
Post #182891 14th Apr 2013 3:30pm
