![]() | Home > Technical (L322) > drivers electric window motor labouring |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
Ill start with the fourums fav, have you checked the battery voltage both when running and not?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
something in the window slide grooves ? ... - .- -.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
the battery voltage is good its only the drivers side with the problem, i have sprayed some silicone fluid in the window grooves. it was my first idea just incase it was a little dry and was causing too much friction but doesn't appear to have helped.
