Home > Maintenance & Mods (L322) > 2nd Battery - does it need to be complicated.
supershuttle
I still have my old battery, replaced with a Bosch S5. I don't think it's all that knackered in fact it may not even be knackered at all, the Bosch still goes flat after a few cold days parked, 20mins with the FBH much the same as the old one. It's currently just sat in the garage and when I think on I connect the C-Tek to charge it. I also use it for camping, air bed inflation, iPod charging and wine cooler etc - I think it's called "glamping". So I think I can just leave it connected to the 12v socket in the boot (always live), assuming I start with it fully charged but I would disconcert it when starting as I know the 12v socket won't take that sort of current required to start the car if the main battery went flat. If this situation arose I would just cart it to the front and use jump leads
Thoughts/opinions
Very Happy Geoff
Post #182848 14th Apr 2013 9:23am
I think there is actually instructions on how to do it on the "new" rave joe90 found the other week. There is nothing that can't be fixed with a hammer😜😜
Post #182855 14th Apr 2013 9:37am
supershuttle
I'll have a look, I bought the hooky CD - less messing Cool Geoff
Post #182860 14th Apr 2013 9:41am
Out of interest I have a 110AH battery sitting in the boot permanently plugged into the boot socket.
The plug has a 10A fuse in it.
Been running round like this for months, never disconnect it for starting.
Certainly works in terms of battery capacity.
When it gets warmer I intend to fit a large second battery in the side compartment connected to the existing setup using 16mm2 cable, 100A rating.
I will put two Anderson connectors in the cables for disconnection purposes.
Nice and simple. Thumbs Up
Post #182878 14th Apr 2013 12:44pm
supershuttle
'nuff said ill order some bits and bang it in. Geoff
Post #182880 14th Apr 2013 1:06pm
There's lots of people say you shouldn't leave them permanently connected as there's something called parasitic drain - when they are not under charge, 2 batteries will start to drain each other - I'm not sure how quickly that takes effect, but if your reason for doing it is to be able to leave the car for extended periods, then worth looking into.
I run dual batteries in my Jeep and have a 200A relay between them that is only engaged with the ignition - I also have solar chargers on both, so that I can leave it without using for extended periods.
Post #182924 14th Apr 2013 7:12pm
