Home > Maintenance & Mods (L322) > 2nd Battery - does it need to be complicated. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3829 |
I still have my old battery, replaced with a Bosch S5. I don't think it's all that knackered in fact it may not even be knackered at all, the Bosch still goes flat after a few cold days parked, 20mins with the FBH much the same as the old one. It's currently just sat in the garage and when I think on I connect the C-Tek to charge it. I also use it for camping, air bed inflation, iPod charging and wine cooler etc - I think it's called "glamping". So I think I can just leave it connected to the 12v socket in the boot (always live), assuming I start with it fully charged but I would disconcert it when starting as I know the 12v socket won't take that sort of current required to start the car if the main battery went flat. If this situation arose I would just cart it to the front and use jump leads
14th Apr 2013 9:23am |
I'll have a look, I bought the hooky CD - less messing Geoff |
14th Apr 2013 9:41am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Out of interest I have a 110AH battery sitting in the boot permanently plugged into the boot socket.
14th Apr 2013 12:44pm |
'nuff said ill order some bits and bang it in. Geoff |
14th Apr 2013 1:06pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7950 |
There's lots of people say you shouldn't leave them permanently connected as there's something called parasitic drain - when they are not under charge, 2 batteries will start to drain each other - I'm not sure how quickly that takes effect, but if your reason for doing it is to be able to leave the car for extended periods, then worth looking into.
14th Apr 2013 7:12pm |
