Home > Technical (L322) > Rear light question
Rear light question
Ive lost count of the numbers of rear lights my dad has smashed on his 2004 car, keeps reversing into walls and posts on the shoot.
When I was fitting his latest OSR unit I noted that the side reflector strip in red had an electrical connection at the back which the car doesn't have on the loom.
So is this light part of a US spec with DRL or something? Can't say I've ever seen one lit up? Discovery 4 HSE
Post #182836 14th Apr 2013 8:46am
Mine are the same with no wiring in the loom part either , only ones I have seen lit are in the States not seen one in the UK , was thinking a while back of getting them wired up tho
Post #182838 14th Apr 2013 8:52am
the american market specified having 'side' lights on the side...hence the new l405 front/rear lights bending around the sides.. ... - .- -.
Post #182839 14th Apr 2013 8:57am
Is there a bulb/bulb holder there too ? Does it work with power supplied ?
Fairly straight forward to connect up to ignition live feed on left hand rear of car to act as a DRL (see what I did with rear reflectors in wiki)
I've not had my rear light units out (yet) so wonder if they are there as standard on only on replacement units? .
Post #182840 14th Apr 2013 8:58am
Re: Rear light question
Yes they were a requirement in North America as were the fronts too sir... Hence the term NAS North America Spec Thumbs Up
Post #182842 14th Apr 2013 9:04am
Tut tut Adam , a Mod posting in the wrong section and getting it moved Laughing Laughing Wink
Post #182843 14th Apr 2013 9:06am
Mick, yours should have (09MY>) LED rear lights already... If yours are NAS spec you won't see any wiring for the side markers as they are LED's too and in the 09my> the LED's and wiring is all hidden... Whistle
Craig Whistle
Post #182844 14th Apr 2013 9:09am
Thumbs Up Cheers Craig , further investigation now is needed as I have always liked the side markers lit up on the NAS ones Thumbs Up
Post #182846 14th Apr 2013 9:17am
Problem is with yours Mick, you can only do the rears as you cannot purchase RHD NAS headlamps Whistle Whistle Whistle
Post #182849 14th Apr 2013 9:24am
Rolling Eyes Rolling Eyes
Post #182851 14th Apr 2013 9:30am
Rolling Eyes Whistle Yawn Laughing
Post #182857 14th Apr 2013 9:39am
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
The front headlights 06-09 do have the fitting for the side markers already there. the sidelight bulb holder fits it so if you managed to source a couple of these then you would just have to wire them in. was thinking of putting led's in the existing sidelights of mine to match the xenon headlights and the normal bulbs in the side markers so as not to bring up any faults or overload anything. any wiring would be inside the headlight unit then. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #182875 14th Apr 2013 12:14pm
RR2008HSE
If he's always backing into posts, I'd check the parking sensors and the rear view camera before worrying about NAS vs Euro lighting differences. Mr. Green Shocked Whistle
Post #182892 14th Apr 2013 3:34pm
Sunday morning laziness Mick. Guilty as charged! Discovery 4 HSE
Post #182901 14th Apr 2013 4:36pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
what is the rear reflector post called in the wiki? Bushy
2003 RR Vogue Monté Carlo Blue
Post #183482 17th Apr 2013 11:14pm
