Home > Maintenance & Mods (L322) > oil pressure warning |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Check your oil level and dont drive the car until then. |
13th Apr 2013 10:55pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
If you only had it serviced on Thursday then, as Katash says, check the oil level and look under the vehicle for signs of oil leaks in case they haven't tightened the drain plug or oil filter.
14th Apr 2013 8:03am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
As above really, i own my own garage and would want to resolve this for you FOC if its our mistake... I fail to see how your car left a garage after a service in that condition though... DO NOT DRIVE it if the oil light is on... This is a critical oil level light not just a warning light...
14th Apr 2013 9:16am |
lee Member Since: 13 Apr 2013 Location: manchester Posts: 2 |
the oil levels are fine , since the oil press warning light started to flicker I stopped and have had the vehicle lifted home waiting for Monday to take it to a recommended garage.
14th Apr 2013 9:57am |
