Home > In Car Electronics (L322) > Satnav red cross
Page 1 of 4 1234>
mackempete
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
Satnav red cross
Hi, thought id move this part of my first post to the ICE forum to see if it gets more attention. I've just bought my FFRR and my Satnav has a red cross through the �GPS� square in the top corner, and its displaying my position in a field in north Yorkshire. I have a 2011\2012 disk on the way to see if this improves things.
I've made it into the satnav diagnosis screen and the "Self Check" screen reports no errors.
I've checked the GPS Information screen (example from manual, not my car):
I have plenty of satellites and their elevation and azimuth info updates as i move, however i'm not getting any reception status from them. i.e. where the example picture above shows P for data being received and T for data being received but not used, i have no letters against any of the satellites.
My Maes status also shows - which indicates, according to the manual, that i'm receiving data from 2 or less sats.
When i picked up the car the computers data was set to 2005 so i dont know if its had the battery off at some point and this has confused the satnav somewhat?
I dont want to start swapping GPS aerials or Satnav drives if there is really a simple solution to this.
Post #181520 6th Apr 2013 11:10am
battery disconnection [details in wiki] then maybe move to a different position ... ... - .- -.
Post #181531 6th Apr 2013 12:06pm
A1GSS
I had a very similar fault on a totally different car (Audi A4). The cause turned out to be a damaged aerial lead - so it was surprising that the SatNav could see the satellites at all. I guess the timing signal wasn't good enough. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #181538 6th Apr 2013 1:07pm
mackempete
Cheers gents. I'll have a go at the battery this afternoon.
When you adjust the position in the navigation config is there anyway to search for a location to move it to? Mine seems to now be in belgium (following my tinkering) that's going to take a lot of scrolling to get to the north east...
If I'm still no further forward I'll explore replacing the gps arial.
Post #181541 6th Apr 2013 2:16pm
belgium is the default country, you need to change it to the uk in the menu.. ... - .- -.
Post #181543 6th Apr 2013 3:03pm
mackempete
Finally got around to disconnecting the battery this morning (explosive charged scared me off at the weekend)
No change i'm afraid. You mentioned setting the default country to the UK then resetting the position to current location. How do i change the default country from Belgium?
Post #182007 9th Apr 2013 2:18pm
if its a touch screen then click on the uk [in the map] and click change..
Post #182013 9th Apr 2013 3:14pm
mackempete
ah ha cheers mate. I've been looking in navigation preferences. Assumed it would be something more system wide.
Post #182019 9th Apr 2013 3:25pm
as for the sat nav red line job, i've done a search here and the conclusion is that there is no conclusion..various answers came up like damage antenna leads to bad connections to faulty units...
the range rover sometimes decides to start working properly all by its own ..
btw the denso manual is in the wiki.. ... - .- -.
Post #182021 9th Apr 2013 3:34pm
mackempete
Reset position to home. Still got a red cross through the GPS. Diagnostic screen still showing satalittes but not getting and position data from them... grrrr
Thanks for your help stan.
See what happens when my update disk arrives though I don't hold out much hope for this making a difference. After that I think we've reached the point of replacing the aerial Big Cry
Sure I saw somewhere that these were a.generic connection.
Post #182097 9th Apr 2013 9:02pm
Johnte
I had the same problem, and had to change the aerial.. But don't worry, cheap (around �50 + VAT) and straightforward job Wink
Post #182115 9th Apr 2013 10:24pm
mackempete
Where abouts did you get yours from Johnte?
Post #182125 10th Apr 2013 6:04am
Johnte
Think it was Dan@duckworths - pm him for a price Thumbs Up
Post #182134 10th Apr 2013 7:50am
mackempete
Thanks Johnte.
Post #182261 10th Apr 2013 6:51pm
super8
2005 Range Rover Supercharged 4.2 SC V8 Java Black
Red Cross - Diag Screen
Hi.... Same issue on my 05 Supercharged... Could someone let me know how I get to the sat diag screen as I can't find any reference to it.... Tried the 1791 hack code but not letting me get anywhere... Thanks. Range Rover - Supercharged - On the drive.
Discovery V8 - Sadly gone.
Post #182668 13th Apr 2013 7:47am
Page 1 of 4 1234>
