Home > Technical (L322) > car shaking at slow speed when brakes applied or in reverse |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 765 |
3 weeks ago my td6 started shaking while moving slowly with brakes pressed either forward or if reversing at slow speed even without braking. If at full stop, the car doesn’t shake anymore, and when accelerating just a bit or moving without braking, there is no shake. The shakes are about 2 per second; I thought the gearbox is the problem, so I changed the oil and filter. Both were changed 5000km ago, without any problem till recently. The replaced oil was OK; there was no metal in it or on the magnet. The oil change didn’t help, so I went to the dealer who plugged the computer, charged 2 hours and told me there is no fault and he doesn't know what to blame. I then went to a BMW gearbox specialist that after a lot of driving said that he thinks it's not the gearbox or the converter, he rather blames an injector that doesn’t compensate well under load. He said proof of this is that even if the gearbox is in N and there is no shake, when the aircon compressor engages the shake can be felt just a little. Help! |
5th May 2010 5:31pm |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 |
What size wheels are on the car? |
10th May 2010 11:22am |
The original ones, 19. The shake started to occur 3 weeks ago, so I don't think the wheels cause it... Also, I checked the brakes too... |
12th May 2010 4:08pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3737 |
have you had the diff recall work done? |
12th May 2010 4:10pm |
No. Dealer said that being a 2006MY the recall doesn't apply to it... |
12th May 2010 9:06pm |
Kilovolt Member Since: 07 Feb 2010 Location: Derbyshire Posts: 104 |
We have a 2010 FFRR TDV8 Vogue .............. it is less than 4 months old ..................... it has 5,000 miles on the clock (can't put it down on Sundays) ................. the stealer fitted brand new front pads and discs last week
13th May 2010 8:39am |
iancollins Member Since: 17 Mar 2010 Location: milton keynes Posts: 264 |
when i bought my 2008 tdv8 vogue from dealer 1 year old ,it was juddeing thru the car when braking but no steering wheel judder
13th May 2010 10:33am |
Ok, looked under the car and then rechecked with the dealer, it seems that although my VIN is out of the affected range (3A101029 – 5A198054, mine being 6A20….), it has the old shaft anyway!
14th May 2010 3:17pm |
Among other interesting things (another) dealer said that injector no. 4 is not functioning properly so this could be the cause... |
17th May 2010 6:24pm |
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 |
exactly the same symptoms I had a few months ago - it was indeed injector no. 4 |
20th May 2010 12:33pm |
No way! What did you do? The injector repair cured it? |
20th May 2010 7:17pm |
smooth as a babys backside once a new injector was fitted |
21st May 2010 10:30am |
This is awesome! I mean compared to a gearbox/torque problem... |
21st May 2010 10:55am |
Right, the computer diagnosis at the main dealer showed: P0314 – cylinder balance control –l-component deviation outside limit. They said that injector no. 4 is at fault and they asked 1000EUR for a new one. I found a repair company and with the help of a local workshop I tried to remove the injector. This proved to be impossible, but while removing the inlet manifold, we saw that one of the round seals was missing.
25th Jun 2010 7:24am |
