Home > Maintenance & Mods (L322) > Anoying Rattle
Stormin
2003 Range Rover HSE Td6 Epsom Green
Anoying Rattle
Ive noticed a rattle when ever i drive over a bump/pothole, it sounds like a heat shield rattling.
Just crawled unter the car and i cant see anything amiss, just wondered if it was a common problem.
Its a 53 plate with 98000 Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #181514 6th Apr 2013 10:01am
mjdronfield
Dust shield behind the brake disks ?
Mine had rusted through where it bolts on, and rattled when I first got it........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #181515 6th Apr 2013 10:07am
Stormin
Thanks
Just checked and as youve suggested, the N/S is loose, i take its a disc off job to replace, are they easy to obtain.
Many thanks
Steve Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #181522 6th Apr 2013 11:22am
mjdronfield
The garage where I bought the car from did mine. They just had it spot welded back, and its still fine 18 months later.
Otherwise its a disc off job, perhaps may be the hub also ?
Don't think they are expensive. Just a pain to swap.
I'd attempt to refasten it on or such like first.
In saying that, I think some have bought new ones, and cut them to slide them round the hub without any stripdown...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #181523 6th Apr 2013 11:42am
its a common problem which has been mentioned before...cant remember the exact solution but if you do a search i'm sure you'll find the threads.. ... - .- -.
Post #181529 6th Apr 2013 12:02pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
undo the two little bolts that hold the cover on then slip a big washer in there, fiddly but it works. Very Happy 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #181537 6th Apr 2013 12:31pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Or if they are too corroded, cut them off and buy new ones. Cutting a small section out if your new shields means they can be fitted without removing brake calliper and disc, just make sure you treat the bare metal edge with paint before fitting. See dan @ duckworth for a price, they are only a few quid. Thumbs Up
Post #181542 6th Apr 2013 2:21pm
Googsy
You would think given their location that Landrover would have used corrosion proof materials Rolling Eyes Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #181562 6th Apr 2013 6:07pm
