Home > Technical (L322) > rear wiper running on ignition
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
hi all
my rear wiper has started to run as soon as i put the key in the ignition. i fitted a new motor about a month ago but now it runs as soon as i put the key in even though the stalk is in the off position. Any ideas?
Matt
Post #181331 4th Apr 2013 9:09pm
wired up wrong Matt or a bad earth maybe. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #181334 4th Apr 2013 9:20pm
mattstevenson2005
havent changed any of the wiring apart from unplugging the old motor and connecting the replacement one. the old motor worked perfectly up until it broke because the plastic gear was worn.
Matt
Post #181340 4th Apr 2013 9:32pm
have a closer look at the stalk, could be shorting out there causing a permanant power supply to the motor. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #181341 4th Apr 2013 9:36pm
....also ,have you tried it with the old motor fitted. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #181342 4th Apr 2013 9:37pm
daveo
hi matt, does it run continiuos non stop or does it run as if you switched it on, ie wipes intermittent V8 facelift Range Rover Autobiography 22" wheels.
Post #181344 4th Apr 2013 9:43pm
mattstevenson2005
it runs as if i have moved the stalk and wipes intermittently
matt
Post #181348 4th Apr 2013 10:00pm
For now you could pull the fuse. Fuse 10 20A on the rear fuseboard.
Post #181352 4th Apr 2013 10:09pm
mattstevenson2005
thats what i have done as its really annoying especially whens its a sunny dry day
matt
Post #181361 4th Apr 2013 10:21pm
daveo
i would say its not a motor issue as it is working as it should,if it was running all the time then maybe yes.. i would go for the stalk first,disconnect the stalk and have a look to see if anything is visable, have a look at rave to see what wires are involved and get you meter on them.. V8 facelift Range Rover Autobiography 22" wheels.
Post #181364 4th Apr 2013 10:35pm
^^^ I agree. Possibly the switch has an earth fault.
Second thing, could be a faulty wiper motor as the ECU is part of the motor assembly.
Post #181365 4th Apr 2013 10:39pm
If you still have the old motor, put it back in to see if the fault is there. There is a chance the new one has been wired incorrectly. I have had to rewire plugs on stepper motors because some manufacturers are too stupid to follow wiring diagrams ! Previously..
Post #181366 4th Apr 2013 10:41pm
