Home > Technical (L322) > rear wiper running on ignition |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
wired up wrong Matt or a bad earth maybe. ... - .- -.
4th Apr 2013 9:20pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
havent changed any of the wiring apart from unplugging the old motor and connecting the replacement one. the old motor worked perfectly up until it broke because the plastic gear was worn.
4th Apr 2013 9:32pm |
have a closer look at the stalk, could be shorting out there causing a permanant power supply to the motor. ... - .- -.
4th Apr 2013 9:36pm |
....also ,have you tried it with the old motor fitted. ... - .- -.
4th Apr 2013 9:37pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi matt, does it run continiuos non stop or does it run as if you switched it on, ie wipes intermittent V8 facelift Range Rover Autobiography 22" wheels.
4th Apr 2013 9:43pm |
it runs as if i have moved the stalk and wipes intermittently
4th Apr 2013 10:00pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
For now you could pull the fuse. Fuse 10 20A on the rear fuseboard. |
4th Apr 2013 10:09pm |
thats what i have done as its really annoying especially whens its a sunny dry day
4th Apr 2013 10:21pm |
i would say its not a motor issue as it is working as it should,if it was running all the time then maybe yes.. i would go for the stalk first,disconnect the stalk and have a look to see if anything is visable, have a look at rave to see what wires are involved and get you meter on them.. V8 facelift Range Rover Autobiography 22" wheels.
4th Apr 2013 10:35pm |
^^^ I agree. Possibly the switch has an earth fault.
4th Apr 2013 10:39pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
If you still have the old motor, put it back in to see if the fault is there. There is a chance the new one has been wired incorrectly. I have had to rewire plugs on stepper motors because some manufacturers are too stupid to follow wiring diagrams ! Previously..
4th Apr 2013 10:41pm |
