Home > Technical (L322) > Pagid front pads/discs sound like a conch blowing |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 |
Are they standard vented or cross drilled/grooved?
30th Mar 2013 8:07pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8517 |
probably need a bit more copper slip on them. There is nothing that can't be fixed with a hammer😜😜
30th Mar 2013 8:20pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
My Mintex with dimpled & grooved squeeled like a pig at low speed. A few high speed all out stops from 70>0 sorted it. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Mar 2013 8:25pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Standard, vented fronts. |
31st Mar 2013 8:53am |
On a long straight private road get upto about 60-70 and brake hard and down to an almost stop without instigating the ABS a few times. This will clear any glaze off the pads and helps a little with slightly warped discs IME.
31st Mar 2013 7:12pm |
