Home > General > Beware the Supercharged - Newbie Buying Advice |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
I stand to be corrected, but I believe the coolant light can come on if the coolant isn't mixed by the correct amount. i.e. too much water and not enough anti freeze, even if the level is correct. |
28th Mar 2013 11:37am |
[quote="Johnte"]I stand to be corrected, but I believe the coolant light can come on if the coolant isn't mixed by the correct amount. i.e. too much water and not enough anti freeze, even if the level is correct.[/quote]
28th Mar 2013 11:42am |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
M/Way MPG depends on how you drive it really, mrs sticks to 70 and gets 21.5/22, I was doing 85 ish other day and was getting 18
28th Mar 2013 11:49am |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 |
I have a 2007MY S/C and I do a mixture of motorway and local driving. I get around 18/19mpg combined and can get 22/23 on a run if I'm very careful (which I never am as that V8 sounds too good to drive like Miss Daisy).
28th Mar 2013 12:00pm |
I have the pre-terrain response / electric handbrake SC.
28th Mar 2013 12:08pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
When you buy it get the spark plugs and supercharger belt changed. Just had mine done and it's probably the best value for money work on a car I've ever had. I went for colder plugs, but that's because mines been tuned a bit.
28th Mar 2013 4:57pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Not sure about the gaps? Surely it wasn't due for a service until 2007, unless a pre-delivery inspection? And a gap of 12k miles, is this a gap, how often does it need a service? I've had a gearbox go on an S/C, but it was higher mileage (130k) and is pretty uncommon. As above, suspension etc. Buy on condition,l low mileage and perfect history are little consolation if things go badly wrong, and to be fair, they are not really that relevant. Condition is the only thing which is. Mileage and history just help with resale value. To properly judge condition, get a professional inspection. I would always get a warranty with a Range Rover now, and I usually go for an inspection by the Warranty Company, a good use of £70 because it means I'm fully covered from day one, including wear and tear! Anyway, good luck with whatever you decide. Range Rover-less at the moment - Pining! |
28th Mar 2013 5:25pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
I see you are in Falkirk - is it a local car ? I'm in Falkirk as well......oh, and I also have a Supercharged I'd say go for it.......but buy an IID Tool to clear any random fault codes ! Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
28th Mar 2013 6:52pm |
Direct from TOPIX:- UK 15000 mile / 12 months My SC was serviced 18 months ago and service light not come on yet but its only done 6K miles so doing an oil and filter change myself for <£50 |
28th Mar 2013 7:30pm |
[quote="Katash"][quote="bozmandb9"]....And a gap of 12k miles, is this a gap, how often does it need a service?[/quote]
28th Mar 2013 10:07pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Rad weld/rad leak = walk away! No garage who knows what they are doing should do that. They should repair the fault not mask it! My 2p worth. Wait there will be many more that come up. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
28th Mar 2013 10:40pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Sounds like too many concerns for you. Walk away and find another. .
28th Mar 2013 10:42pm |
You're probably right.. Complete waste of a day!!! |
28th Mar 2013 10:52pm |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4989 |
yep get a full service history one - like i did - i drive only in town and get a 9mpg only issue i had as a leaking radiator. All my spelling errorz are belong to me!
29th Mar 2013 11:56am |
