Home > Maintenance & Mods (L322) > Massive power drain on new battery
Saltyfish
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
As mentioned before check the Sat Nav unit, i had very similar issues and found my Sat Nav was not shutting down. I now unplug it till it is required untill i source a Mk4 unit. Ive had no issues since unplugging it. Cool 04 Vogue 4.4LPG.
01 Vogue 4.6.
00 Vogue 4.6LPG.
99 Discovery ES 4.0LPG
96 Discovery ES 3.9LPG.
Post #180059 28th Mar 2013 4:34am
Andy
I'll try that. The dash screen doesn't work anyway, so I might as well unplug it.
Post #180061 28th Mar 2013 7:38am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Noddy. As you've had a few flat battery episodes, even if you find the drain, it is likely that your battery is no longer up to the job (as Stan said earlier). You may need to get a new battery, then go through all the testing again to make sure. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #180063 28th Mar 2013 7:44am
Andy
Agreed. Once I find the receipt from euro car parts, it's being swapped
Post #180077 28th Mar 2013 10:16am
Andy
Checked the Satnav the other night and the little LED was flashing. I've disconnected it for now until I can get the dash screen working again.
No issues so far, fingers crossed.
Post #180315 29th Mar 2013 5:21pm
dan_uk_1984
Re: Solution - Back up battery
Dolphinboy wrote:
Maybe he can be invited out of retirement (I know you're watching somewhere Dan!!) and let us know how he did it.
I will try and get some pics up tomorrow.
Quite an easy job, the biggest PITA was finding a battery that fitted.
There are a couple of nice chunky spots to tap into on the rear fuse board distribution board inc an 100Amp fused terminal if my memory is correct.
Also the way the system is wired, if you disconnect the main battery the whole system still goes dead, so the pyrotechnic charge on the front battery will still disconnect both.
In fact, for your pleasure I have dug out my old post: http://www.fullfatrr.com/forum/topic5721.html
Where did I find the time to post as much as I did!? (oh yeah, whilst at work - LOL)
Post #180364 29th Mar 2013 9:28pm
dan_uk_1984
Did you wait 15 mins for the system to shut down before you assumed this was at fault?
Best way is to fold back the parcel shelf, and open the panel and then close the car up. Opening any door will wake the system up again.
The other telltale that the system is still awake is the LED on the gear selector. The whole time it's lit the whole car is awake still.
When cleaning the car, open every door first, as it's the closing and opening that wakes the car, not the act of having the doors open. Best to turn the interior lights off manually, although they will turn off after 10(?) minutes, but they can get so hot they can distort the plastic lens.
Sheep
Post #180365 29th Mar 2013 9:31pm
A very small and quiet leak in the EAS suspension can also cause battery drain (from experience)
When I put my rear suspension back together I didn't get the airbag connector quite right. No sounds of hissing but over a 12 hour period the bag would completely deflate.
However, the EAS tried to keep up with the air loss by running the compressor at regular intervals.
If there is a very minor (more minor than I have described) leak in the system somewhere, this could contribute to battery drain and you may not know it was the EAS as the compressor was able to keep up with the leak? .
Post #180371 29th Mar 2013 10:14pm
dan_uk_1984
Joe90, the levelling performed every few hours (6?) should only ever be "down".
So if one corner had a leak and dropped an inch, the remaining 3 corners would be lowered to match, until it hits the bump stops. This is why if you park on uneven ground it will sometimes lower itself to the stops.
Post #180383 29th Mar 2013 11:41pm
Doesn't happen! One corner dropped, once the car had run out of air, the others stayed up. "Tested" in Std and O/R height. .
Post #180384 29th Mar 2013 11:49pm
Andy
Dan- I didn't bother checking that thoroughly. As the dash screen hasn't worked for some months now (due to either a poor connection or the unit u/s in the boot), I don't have a need for a working satnav so I just unplugged it for now.
Post #180406 30th Mar 2013 8:45am
dan_uk_1984
If that's not working then I'd start around that area... Maybe it has some moisture in there.
Post #180532 31st Mar 2013 12:05am
