Home > Technical (L322) > TPMS wiring diagram
Paul J.
TPMS wiring diagram
Hello,
Does anyone have the wiring diagram for the TPMS?
I'm having problems with my TPMS. It keeps flashing up the message 'check all tyre pressures', despite them all being fine. I had the car in for a service today, and the dealer's technician began looking for the problem, but ran out of time, as I needed the car back. I suspect they checked the obvious things, because they said they needed to start checking the wiring (the time consuming bit). I am sufficiently handy to carry out these checks if I had a wiring diagram.
I wonder whether there are any connectors that are susceptible to damage or water ingress, because the problem was very intermittent until a recent jet wash, when it became almost a constant feature of the dashboard.
TIA
Paul
Post #147518 22nd Oct 2012 6:21pm
Post #147520 22nd Oct 2012 6:29pm
Paul J.
Thanks for the quick reply!
....... erm ....... do you also have diagrams showing the wiring arrangement for this system to show where the various wires and sensors are routed/located Embarassed
Paul Thumbs Up
Post #147522 22nd Oct 2012 6:41pm
mjdronfield
It's all in RAVE, which is downloadable from the Wiki section.
Well worth downloading and putting on your PC.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #147526 22nd Oct 2012 6:54pm
Paul J.
Thanks,
Will have a look (after a loooooooooooong downloading session) Very Happy
Paul
EDIT - The link on the wiki is a relatively small download, compared to some sources I had previously googled.
Post #147527 22nd Oct 2012 7:05pm
elmer
2008 Range Rover Vogue TDV8 Java Black
Hello,
did you find where the problem was? My rr has the same problem and oficial service canīt mind it.
I canīt watch the TPMS wiring diagram because it has disappeared
Thanks
Post #179605 25th Mar 2013 10:51am
Sorry about that. ^^^^
Post #179609 25th Mar 2013 11:30am
elmer
Thanks for wiring diagram.Do you know where is ECU tyre deflation placed?
Post #179731 26th Mar 2013 10:50am
Under front passenger seat, below BCU. Thumbs Up
Post #179732 26th Mar 2013 11:04am
