![]() | Home > Technical (L322) > 07 TDV8 gearbox oil leak |
STMVOGUE2010 Member Since: 23 Aug 2012 Location: Alloa Posts: 100 ![]() ![]() |
If I were you I'd hire a car......till fixed. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Is it leaking from the bolted seam on the transfer case? Its the seam with the inverted torx bolts holding it together.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
a/c water capilarating to that area... ... - .- -.
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
I keep monitoring the situation, as Ive only had the car 4 days!
I assume that when you looked at the gearbox oil level, the engine was running (with the gearbox in neutral and on the handbrake, level parked etc.). If you don't have the engine running, the level is too high |
Thanks for that, no didn't have engine ruining...........shall check again tomorrow. |
So, to clarify... start engine, select neutral, remove plug {alan key head] and the oil should be level with th hole? |
Yep and the gearbox temp should be between 30 and 50 C.
So, you remove and check the level with the engine running? |
Yes, with the engine running to "keep the oil in the gearbox hydraulics"
Thanks for that, done as you suggested, took for a drive around the block, came back, went through the gear positions, sat it in neutral ticking over. When I undone the fill bolt and started to remove,oil started to come out..so it seems that it`s not low.
Doesn't sound too low. Transfer box may have a little more but 4 mm is not major. Hope they don't find a major issue. MY 2010 5.0 SC Galway green and sand interior!!
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Worth remembering that the tiniest oil weep looks far worse than it (usually) is as a little oil makes a lot of itself! Unless you are getting pools of oil on the floor, it's not a major leak! |
Garage just called and cancelled appointment !!
