Home > Technical (L322) > Brembo brake upgrade
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Has anyone upgraded their brake calipers to Brembo?
I'm changing my pads soon and wondered whether this would first be a good upgrade and second if its relatively straightforward to carry out.
Post #179518 24th Mar 2013 5:45pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Yep, fitted a brand new TDV8 brembo setup recently. Job went very well, due to the callipers never being fitted before I had to run a tap through the threads and I also bought the wrong discs first time round. All in all it was a cheap and very worthwhile mod, breaks are much sharper and have a great feel. Don't expect racing performance though, they can't change the laws of physics.
I fitted everything new and I think I spend £400-£500 max.
Bits needed :-
Brembo TDV8/SC callipers & pads
Matching dust shields (optional)
TDV8/SC flexi hoses
360x30 discs (I bought dimpled & grooved)
Good quality brake fluid (I bought ATE racing blue)
Post #179525 24th Mar 2013 6:18pm
Rich86
Steve, thanks for the info. Would these be the same for my standard 52 vogue v8 petrol?
Post #179527 24th Mar 2013 6:21pm
SteveyD
someone will confirm but yes they will fit the same. Only difference between TDV8 and SC brembo callipers is the colour (grey or black) currently your car has single piston callipers with 345x30 discs.
Post #179529 24th Mar 2013 6:26pm
Also make sure you have 19"+ rims Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #179538 24th Mar 2013 6:46pm
mjdronfield
Do you need to have 20" wheels ?
Currently have 19's fitted.........
Cheers 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #179539 24th Mar 2013 6:48pm
mjdronfield
Ah, beat me to it !!
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #179540 24th Mar 2013 6:49pm
Yes Brembo's will fit on all FF's but the later (bigger 6 pot) Brembo's with Range Rover written on them for the 09> MY wont fit the earlier models as the bolt/mounting holes are too small on the 02-08 hubs...
When fitting Brembo upgraded calipers you can either cut down the dust shield to save replacing them to save a few £££'s or replace them to do the job correctly Thumbs Up
Remember there are two bleed nipples on Brembo's not the usual one found on standard calipers Thumbs Up
And finally, Sport Brembo calipers will not fit the FFRR so don't make the same mistake i and many others have done in the past... (at least they fitted my D3 last week after sitting on the shelf for over 12 months Rolling Eyes )
Craig Thumbs Up
Post #179580 25th Mar 2013 1:32am
mjdronfield
I'm pretty interested in this upgrade.
Do you not have to upgrade the rears also ?
How does the ABS and DSC and EBD and all the other 3 letter acronyms manage if you do this, as there will be more braking bias to the front, will there not, if the rears aren't done ?
Perhaps I'm over thinking it..........
Seems a mad price for used Brembo calipers on the bay. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #180421 30th Mar 2013 11:46am
Rich86
I would upgrade to Brembo all round as there's a noticeable improvement apparently.
A mate has Brembos on his Sport and he says it stops much better than before.
Post #180698 1st Apr 2013 2:02pm
TtheArab
2003 Range Rover HSE 4.4 V8 Giverny Green
Just managed to pick up calipers. Anybody have part # for dust shields ?
Post #184963 26th Apr 2013 6:25pm
http://www.fullfatrr.com/forum/topic17841.html
give ducky Dan a shout .. ... - .- -.
Post #184970 26th Apr 2013 7:07pm
TtheArab
Thanks. Found part # on microcat by removing my VIN and just scanning SC profile. Now ordered alongide sensors. Will refurb Brembo's and then fit these when I swap out the 18" alloys later in the year. Good to have it all there and ready.
BTW anybody found who is best for Brembo caliper refush and coat / paint ?
Post #185093 27th Apr 2013 1:29pm
Brembo don't do standard rear calipers... IE if you have an SC or TDV8 with Brembo's, they are only the fronts Thumbs Up
Post #185108 27th Apr 2013 3:35pm
mjdronfield
Thanks Craig.
Will keep my eye out for some front Brembo calipers then, if the electronics don't get all screwed up on a 2003.......
How much do you think it would cost to convert the fronts with all new parts, ie disks, pads, calipers, hoses, fluid etc ?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #185187 27th Apr 2013 9:08pm
