![]() | Home > Technical (L322) > My TDV8 does not like Junk Food |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
these faults , did you get fries with them... |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
It does not seem to differentiate between breakfast and daytime menu's 2011 Stornaway Grey 5.0SC Autobiography |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Its self lowering for the drive through you fool! Do ya know nothing |
Found the issue now. It must be because I am pressing the brake pedal hard while fishing out my wallet.
I bet it the dealer loaded the new "get fit through good food" diet program. It links the GPS and the microphone to the central server at JLR and when the server software sees it is a "bad" food place, the ECUs are told to generate random faults |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
It may contain traces of nuts. |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
When I drive my M3 past a ceratin part of the road on the way to work (beside a railway crossing) my ABS light almost always comes on - It only ever does it at that part of the road - must be radio interference of some sort. If i stop and restart then the light goes out and stays out........ Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Unfortunately it seems to be getting worse, but the fast food thing was a red herring and purely coincidental. Now getting all of the following if I press the brake pedal hard while stationary
Start looking at voltage (battery and/or alternator) issues and grounding issues. This sounds like crooked volt issues. MY 2010 5.0 SC Galway green and sand interior!!
Battery and alternator not much more than 6 weeks old so hopefully not.
Your ECU must be "Fried" then....
Oddly, the only time mine has done this was at a McDonalds too...... |
