Home > Technical (L322) > Compressor Question
nic_68
Compressor Question
Evening,
A question regarding the air compressor. How long should the compressor run when starting after the car has been left in access height mode for several hours? Mine is running for a good minute or 2 before it stops. It's fine after that.
Thanks
Nic 2007 RR SE TDV8 in Stornoway Grey
2005 RRS First Edition in Buckinam Blue :Gone
Post #178786 21st Mar 2013 12:31am
It shouldn't be that long as there should be air in the reserve tank as well enough to get it up quickly. It sounds like you may have a slight leak somewhere.
Running the compressor for 2 minutes gets it very warm indeed which could lead to a quicker failure of the unit Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #178798 21st Mar 2013 9:46am
