Home > Technical (L322) > EAS: Reservoir Pressure Static When Filling ?
Member FEM888 (Dave) came over this evening so we could put his car on the All Comms to see what was going on with his EAS.
It's a very nice black '03 HSE with only 47K on the clock, but had the good old "AIR SUSP INACTIVE" on the message centre and was stuck at standard height (although it would drop to Motorway height at speed and eventually return to Standard Height)
Had a quick real world measure with the tape, and confirmed car was at Standard height, give or take a few mm here and there.
AllComms delivered the following and only fault on the EAS:
We cleared the fault and could hear the Compressor kick in. Went to Off Road height but this took @ 90 seconds. Ran the test again and the fault was back. Dropped back to standard height, ran the test again and the fault had returned. Left car with fault cleared.
Points me to either:
Compressor knackered
or
Leaky reservoir, probably at the valve
Thoughts welcome.... Thumbs Up .
Post #178736 20th Mar 2013 8:54pm
Compressor goosed! Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #178743 20th Mar 2013 9:02pm
http://www.fullfatrr.com/forum/post15990.html
this might explain it.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #178745 20th Mar 2013 9:03pm
Meerbusch
Hallo Joe90, first change the pressure-sensor, and also refit your compressor, cheap only the piston ring, enough for 6 month, or complete refit for long life..., best regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #178747 20th Mar 2013 9:05pm
Thanks Stan, never resolved in that thread, though Sad
So compressor , pressure switch or pressure sensor........ or battery? .
Post #178775 20th Mar 2013 10:27pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I gues its the compressor - mine went arround that milage as well, at that time - arround 6 years ago they changed the whole compressor, now i would just do the ring
static means there is no fluctuations noticable, hence the compressor is not able to put air in the system
go for the replacement ring
Post #178804 21st Mar 2013 10:05am
sounds like its a process of elimination Tim..start with the cheapest i suppose.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #178815 21st Mar 2013 10:17am
Remembering it is not my car that has the problem, but if it were me I would want to find a kind soul who was prepared to swap out compressors first. .
Post #178817 21st Mar 2013 10:20am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Can't you try your compressor on his car - and vice-versa?
Post #178832 21st Mar 2013 11:02am
Tims range is about 40 foot up in the air at the moment so that would be difficult... Laughing ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #178833 21st Mar 2013 11:04am
Simes
Something like this is needed then:
Post #178834 21st Mar 2013 11:07am
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #178837 21st Mar 2013 11:14am
Rolling with laughter Rolling with laughter
True. I opened the tailgate yesterday, could just about rest my chin on it standing up Laughing .
Post #178848 21st Mar 2013 12:01pm
Joe get he compressor out and strip it down. There a how to in the wiki. Just a light sand of the piston ring to rough it up and some vacuums grease will have it running much better and give you an idea if the compressor is Censored or if its the pressure switch. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #178907 21st Mar 2013 3:40pm
Joe if its not a big job is there not a working compressor he could swap with and then see if the fault clears?
This would be easy and cheap as its only time if you have one thats working at the minute and will then show what the real fault is Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #178914 21st Mar 2013 4:07pm
