Home > General > Late TD6 or Early TDV8?
CEEGEE
I'm planning a return to a RR (have had 2 sports and 2 P38's in the past), but this time looking for a very useable Vogue, which will give reliable and (relatively) low cost motoring - I don't want to worry every time I set off on a 400 mile round trip, or worry to death about "the next service" and the dreaded call from the garage at around 10.30 in the morning to tell you how much needs doing. I am prepared to spend up to around £20/21k. So, am I better with a late (face lifted) TD6 or an early TDV8?? How important is mileage - do I need to be worried or be looking out for certain problems over, lets say 50/60,000 miles?? In general, what do I need to watch out for?? Thanks for any help and advice you can give. Smile
Post #178652 20th Mar 2013 4:06pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
You should get a tidy TDV8 for that sort of money ... Thumbs Up African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #178654 20th Mar 2013 4:10pm
CEEGEE
But the question is, is it better to have a low mileage "nicer" TD6 or a higher mileage TDV8, and which will be the most reliable and cost effective to run??
Post #178655 20th Mar 2013 4:19pm
i would peruse down this section ...this question pops up weekly and there have been some very valid points made.. ... - .- -.
Post #178656 20th Mar 2013 4:30pm
GreenBlood
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
I debated the same question in November and had a similar budget. Ended up going with an 07 TDV8 with 58k miles for £25k from a LR Dealer. I suppose that I could have gotten cheaper if I was prepared to go with an independent or private sale but I wanted the 'LR Approved' stamp.
I get 450-500miles per tank and there is plenty of response when I step on the loud pedal. If you don't get stuck then you are not trying hard enough.
2012 FFRR TDV8 Westminister
Gone: Def90 2.8i, Def110 2.8i
Gone: RRC 2-Door and 4-Door, 2007 FFRR TDV8 Vogue
Gone: Aussie Spec D1 V8, D2 V8
Post #178657 20th Mar 2013 4:30pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Depends on you really...do you like to just potter about at 50mph? Or do you like a bit of performance and possibly need to tow a trailer? If it's the former then the TD6 will be perfect if it's the latter and you can pick up a cared for TDV8 with motorway miles then that's the one to go for....Everyone has their own opinion but as your asking mine is TDV8 everytime Thumbs Up
Post #178658 20th Mar 2013 4:35pm
I have a TD6, would prefer a TDV8. For me the only argument is an old TD6 or stump up the cash and get a TDV8. As soon as they get closer in price you really have to go for the V8 - it's a much better car.
Post #178666 20th Mar 2013 5:16pm
To echo Stan: -
http://www.fullfatrr.com/forum/topic16012.html
Post #178667 20th Mar 2013 5:19pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I bought a 1 owner 69k 07 Vogue SE for £23k last June
Independent, not a LR dealer so perhaps a little over the odds, but the car was immaculate inside and out. Every single thing on it worked....and still does!
12k miles later and the only money I've spent (other than routine service) was £65 to have a front lower arm replaced (or £800 at a dealer Rolling Eyes )
I went for a TDV8 because I wanted a facelift model and the extra power. I have not regretted that decision for a second Mr. Green
You should be able to get a very tidy TDV8 for £20k
As ever, buy on condition - everything else is secondary..... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #178668 20th Mar 2013 5:19pm
CEEGEE
Some really great feedback, I suppose my heart wants to go for the TDV8, but wasn't sure if it had much higher running costs, accepting that the MPG is comparable.
It sounds as though a good history is really important - are there any "key" jobs that should be done at certain mileages? I'd want to look for these in any history file.
Post #178687 20th Mar 2013 7:21pm
Have you seen this one I have in stock with full Guy Salmon Service History, 4 New Tyres and spotless In and Out:
http://www.garyelliott.co.uk/prestige_cars...index.html
Post #178698 20th Mar 2013 7:47pm
If you have the cash to burn I would get a 05/55 or early 06 TD6 if you dont need performance and the 10k you save can go in the bank.
As soon as you get it then get the gearbox flushed and the filter changed and do the diff oils and a full service and you should get that all done for about £6-800 easy so have £200 left for your first tank and a bit of fuel Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #178734 20th Mar 2013 8:54pm
Lloyd Barnes
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I just sold my 08 TDV8 for £21k. It did have 87k miles on it but it was spotless and very reliable. £21k ought to easily get you a slightly lower mileage 56/07 TDV8. I've sat in a TD6 and I have to say the TDV8 is a nice update inside. For me trying to spend £20k on a TD6 makes no sense. Either lower the budget a fair bit or get a TDV8 IMHO Smile
BTW, I'm on the lookout for a nice 10 plate TDV8 and the general advice is to hang on a while as well as the prices are higher when the weathers chilly Thumbs Up Lloyd Barnes
Current
Crendon 427 Sideoiler Cobra in build... 7 litres of madness!
Gone
2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer
2008 VW Touareg 3.0Tdi
6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph Smile
Post #178818 21st Mar 2013 10:22am
