Home > Technical (L322) > TURBO FAILURE TD6 |
pyramid1235 Member Since: 25 Mar 2009 Location: Glossop Posts: 20 |
My turbo failed on my TD6 it took about 3 months to fail completely started off with a low whistling noise when the engine was warm did not happen when the engine was cold and only on acceleration upto 3000rpm.
3rd Feb 2010 11:51am |
My attempt to attach pic failed!! cant remember how to had if someone can post instructions for me i will post a pic of where the crankcase breather filter is.... |
3rd Feb 2010 11:54am |
http://www.fullfatrr.com/forum/topic1022.html
3rd Feb 2010 11:59am |
3rd Feb 2010 12:10pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
from what you say it sounds like it was the turbo. Has replcing the turbo rectified the fault ? and also i replace that breather in mine each service and it gets proper thick with crud but how does that contribute to the turbo failure ? onto no6 Range Rover
3rd Feb 2010 6:06pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 766 |
Did the noise sound like blowing in a bottle? I sometimes have such a noise between 1500-2000RPM and it goes away when accelerating. I too changed the valve breather filter (http://www.fullfatrr.com/forum/post8223.html#8223) but I can't see how it would lead to turbo failure... |
3rd Feb 2010 7:34pm |
replacing the turbo has rectified the fault everything running as it should be no more strange noises... I'm not sure why the filter is so important just what i was told when purchasing the turbo, the chap really seemed to know what he was talking about explaining how the system should work etc., but did not mean a lot to me sounded very technical! |
3rd Feb 2010 10:49pm |
Yes, the noise started off sounding like blowing in a bottle, hope you dont have the same problem.. |
3rd Feb 2010 10:55pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
My saviour!
29th Apr 2010 10:14am |
Good news
1st May 2010 9:56am |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Ok. I have the whistle. I have researched this though and been assured this is normal as this also features on many X5's and BMW unitis to though I still need to be completely convinced. I am sufficently at one with the idea until the Turbo dies
1st May 2010 2:35pm |
Captain Slog Member Since: 16 Jul 2010 Location: Derbyshire Posts: 49 |
I've had TWO replacement Turbo's on my 2005 TD6. The first when I purchased it. It had done 25,000 miles and was making a noise that sounded like I was being chased by the cops, a rising and falling siren sound between 2000 and 4000 rpm. The stealership swapped out the Turbo before I handed over the cash.
16th Jul 2010 7:27am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3738 |
the blowing in a bottle sound / woosh on the over-run (this is the wastegates) and whistle is normal, all the TD6's I have driven did this - even brand new ones. |
16th Jul 2010 9:14am |
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 |
I have this whistling on boost and was told that my turbo is overboosting. How is that possible if the wastegate is working? |
10th Aug 2016 7:18am |
