![]() | Home > Technical (L322) > TURBO FAILURE TD6 |
pyramid1235 Member Since: 25 Mar 2009 Location: Glossop Posts: 20 ![]() ![]() ![]() |
My turbo failed on my TD6 it took about 3 months to fail completely started off with a low whistling noise when the engine was warm did not happen when the engine was cold and only on acceleration upto 3000rpm.
My attempt to attach pic failed!! cant remember how to had if someone can post instructions for me i will post a pic of where the crankcase breather filter is.... |
http://www.fullfatrr.com/forum/topic1022.html
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
from what you say it sounds like it was the turbo. Has replcing the turbo rectified the fault ? and also i replace that breather in mine each service and it gets proper thick with crud but how does that contribute to the turbo failure ? onto no6 Range Rover
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 793 ![]() ![]() ![]() |
Did the noise sound like blowing in a bottle? I sometimes have such a noise between 1500-2000RPM and it goes away when accelerating. I too changed the valve breather filter (http://www.fullfatrr.com/forum/post8223.html#8223) but I can't see how it would lead to turbo failure... |
replacing the turbo has rectified the fault everything running as it should be no more strange noises... I'm not sure why the filter is so important just what i was told when purchasing the turbo, the chap really seemed to know what he was talking about explaining how the system should work etc., but did not mean a lot to me sounded very technical! |
Yes, the noise started off sounding like blowing in a bottle, hope you dont have the same problem.. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6415 ![]() ![]() |
My saviour!
Good news
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Ok. I have the whistle. I have researched this though and been assured this is normal as this also features on many X5's and BMW unitis to though I still need to be completely convinced. I am sufficently at one with the idea until the Turbo dies |
Captain Slog Member Since: 16 Jul 2010 Location: Derbyshire Posts: 49 ![]() ![]() ![]() |
I've had TWO replacement Turbo's on my 2005 TD6. The first when I purchased it. It had done 25,000 miles and was making a noise that sounded like I was being chased by the cops, a rising and falling siren sound between 2000 and 4000 rpm. The stealership swapped out the Turbo before I handed over the cash.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
the blowing in a bottle sound / woosh on the over-run (this is the wastegates) and whistle is normal, all the TD6's I have driven did this - even brand new ones. |
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 ![]() ![]() |
I have this whistling on boost and was told that my turbo is overboosting. How is that possible if the wastegate is working? |
