Home > General > Soon to be new FFRR owner with questions |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
http://portal.jeengineering.co.uk/engines/diesel-tunes.html
14th Feb 2013 8:26am |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 784 |
Booked my 4.4 TDV8 in at JE for their re-map on Wed
18th Feb 2013 12:16pm |
campaj1 Member Since: 22 Oct 2012 Location: Cheshire Posts: 729 |
brilliant, will be great to hear about the results! |
18th Feb 2013 12:17pm |
mikef Member Since: 30 Jan 2013 Location: Bucks Posts: 82 |
Yup, I'd be very interested in hearing what difference it makes to the performance and the fuel consumption because in my experience, remaps do improve fuel consumption too |
18th Feb 2013 2:17pm |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 |
Ipanema Sand is a very nice colour All my spelling errorz are belong to me!
18th Feb 2013 3:08pm |
Probably should start a new thread (sorry OP).
20th Feb 2013 8:52pm |
Thanks, Phil |
20th Feb 2013 9:54pm |
mikef
21st Feb 2013 7:36pm |
Thats v impressive. 10% improvement is more than I've seen on the various turbo diesel BM, Merc and Audi remaps I've done in the past. Sounds like its well worth it. Do JE say anything about how detectable the remap is by L-R diagnostic tools? |
22nd Feb 2013 9:18am |
They were very careful when opening the ECU and have reasealed it so it is difficult to tell it has been opend. No discussion regarding diagnostic tools but a dealer would notice it if they drove it I'm thinking of having mine serviced by JE even though it's still under warranty. It's had all the current software upgrades and they know more than most dealers about LR maintenance. The only issue is if some thing goes pop and I'm prepared to take that risk. MY23 D350 HSE On my 7th RR plus various other JLR vehicles |
22nd Feb 2013 10:46am |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Ford Hill, Wirral. Not Merseyside Posts: 554 |
Sounds like the carpet has been wet vacced and then the car has been sat doing nothing, hence getting cold. However check the sunroof drain tubes. These sometimes block and can cause water to enter the footwells as there is no escape. I know of dealers who do the quick fix by removing the non return valve in the drain tube, as it drains down near the wheel arch somewhere. Worth also checking the window door seal. Make sure it hasn't been pinched.
10th Mar 2013 12:08pm |
Thanks Big Boy R44ROV for the heads up on the leak. I think you may be right on the wet vac because after a few weeks of use, I'm noticing the misted up windows less and less. However I am starting to learn about the little foibles of FFRR ownership already; it's definitely not like owning a German car and I mean that in a good way as well as a bad way. Yes, after 2000 miles, the apparently new Contis fitted by the dealer are already showing signs of wear and it won't be too long before I have to bin them. My car is still under the manufacturer's warranty. Does anyone know whether fitting tyres that were not original fit would void the warranty in any way? I'm thinking that if, by chance, I get any kind of suspension issue, the dealer might try to deny the claim by saying I had fitted non standard tyres.
11th Mar 2013 11:51am |
Hello mikef.
11th Mar 2013 12:04pm |
Yes you're absolutely right. The FFRR is about the most soothing car I've ever owned; it is definitely one of those cars that make you feel good about driving it and I suppose that is why people keep buying them |
11th Mar 2013 12:09pm |
