Home > Technical (L322) > Starting Issue (Dies After Firing) |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Happened to me today for the first time but mrs says it has happened to her too - Usually when I get in I put key in, turn to pos 2 and put seatbelt on before I crank - today I didn't ..... Wondering if I didn't give enough time to prime. |
6th Mar 2013 11:06pm |
Same with mine before I replaced the fuel pump unit in the tank and had the injectors cleaned and the inlet manifold. Is was super smooth running after that and starts on the turn of the key (unless it has been sitting in the sun for a while in the plus 30 temps here, then it takes a second or two to fire).
7th Mar 2013 7:42am |
CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82 |
Mine did this recently, new MAF fixed it instantly.
9th Mar 2013 2:55am |
9th Mar 2013 2:56am |
On mine the new OEM MAF had no effect. MY 2010 5.0 SC Galway green and sand interior!!
9th Mar 2013 7:02am |
Seeing as this is the easiest I may give tis a try .... Although its been perfect since Thanks guys |
9th Mar 2013 12:30pm |
The MAF is not that cheap, just clean it first and see if there is an improvement. Use cleaning alcohol and a cotton bud, be careful not to damage anything.
9th Mar 2013 12:58pm |
