Home > Technical (L322) > Starting Issue (Dies After Firing)
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Occasionally getting this issue, normally after 1-2 days of not being used
Cranking engine fires pretty quickly but doesn't do the normal 1000ish rpm burst, it splutters and dies within 1-2 seconds
Normally this happens twice and the third time it will fire up and be fine, once running the engine is fine and runs perfectly smooth, suggests to me filter and pump are fine.
Gut instinct is there is fuel starvation.
Any ideas?
Post #176266 6th Mar 2013 10:53pm
Katash
Happened to me today for the first time but mrs says it has happened to her too - Usually when I get in I put key in, turn to pos 2 and put seatbelt on before I crank - today I didn't ..... Wondering if I didn't give enough time to prime.
Post #176267 6th Mar 2013 11:06pm
ebajema
Same with mine before I replaced the fuel pump unit in the tank and had the injectors cleaned and the inlet manifold. Is was super smooth running after that and starts on the turn of the key (unless it has been sitting in the sun for a while in the plus 30 temps here, then it takes a second or two to fire).
Now I am not suggesting to replace the fuel pumps (very expensive although I was lucky that Kingpleb found a cheap set on Ebay for me Smile )but I would suggest to :
- Replace the intank filter (the filter is not that expensive, I paid something like 60 Euro at the Dutch dealer, but it is a bit of work).
- Run injector cleaner for a while as well as very clean fuel (V-power and the likes).
If that doesn't help, do a full clean of the inlet manifold (quite a job though but you could do it yourself) as they get horribly dirty inside (partly because the surface is rough as guts, I think if you would polish it, it would make the world of difference in power delivery but that is beside the point) and next step, get the injectors removed and cleaned.
I tried the same trick as you, let it prime for a while but that doesn't seem to work at all. With the new set-up it actually works against. If I just turn the key straight to start it will fire immediately, if I leave it on prime for a bit, it takes a bit longer to fire sometimes. MY 2010 5.0 SC Galway green and sand interior!!
Post #176292 7th Mar 2013 7:42am
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
Mine did this recently, new MAF fixed it instantly.
Ensure you get genuine Bosch, cheaper OEM was a waste of money for me. L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #176704 9th Mar 2013 2:55am
CBH25
Post #176705 9th Mar 2013 2:56am
CBH25
Post #176706 9th Mar 2013 2:56am
ebajema
On mine the new OEM MAF had no effect. MY 2010 5.0 SC Galway green and sand interior!!
Post #176707 9th Mar 2013 7:02am
Katash
Seeing as this is the easiest I may give tis a try .... Although its been perfect since
Thanks guys
Post #176751 9th Mar 2013 12:30pm
ebajema
The MAF is not that cheap, just clean it first and see if there is an improvement. Use cleaning alcohol and a cotton bud, be careful not to damage anything.
Also run injector cleaner and "clean" fuel for a bit (V-power), it can sometimes help. MY 2010 5.0 SC Galway green and sand interior!!
Post #176754 9th Mar 2013 12:58pm
