Home > In Car Electronics (L322) > Bluetooth Install
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Bluetooth Install
Now I'm nearly ready to do this (hopefully this weekend) but have hit a snag already.
I have the ULF Module, new mic and a wiring loom (on its way) but can't find an arial or arial plug.
I assume I'll need this at some point.! Any clues where to go and what to get?
Thanks
Ash Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #176341 7th Mar 2013 12:05pm
mjdronfield
Do a search for bluetooth antenna.
Should give you some results.
A BMW part.............
Or same on ebay.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #176435 7th Mar 2013 7:12pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
part number from bmw is 84506928461 £14.44 plus vat. :thumbsup:if when your loom adapter kit comes it fits the white 12 pin plug ok could you post a part number please so i can buy one rather than make one.
Post #176458 7th Mar 2013 9:11pm
comports
Thanks Aaron
This is annoying because I know I have one of these but can't find it now. I will however also need the lead from arial to UHF. Don't suppose anyone has a part number for that do they?
Thx Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #176475 7th Mar 2013 10:00pm
comports
Guys
I need your help - I need the connection lead from the bluetooth antenna to the ULF. BMW guy cant find anything..!
If any of you have done the bluetooth upgrade, would you be able to see if the cable has a part number on it for me to quote to BMW?
EDIT: Part number 61120137616 is the arial cable. Please shout if anyone has a spare. (unlikely) as they are on back order from Germany Sad
Thanks
Ash Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #176559 8th Mar 2013 11:18am
ccfj1
comports wrote:
Guys
Thanks
Ash
comports wrote:
Long shot Dan but I need the cable that links the bluetooth ULF unit to the bluetooth antenna.
BMW part number is 61120137616 but that may not be any use to you.
Can you supply something like this?
Thanks
BMW part 61-12-6-912-541
or
http://www.ebay.co.uk/itm/GPS-1m-Antenna-E...1c2bcbef5c
or
http://www.ebay.co.uk/itm/Radio-antenna-Ex...45f4f5a019
or
www.ebay.co.uk/itm/Fakra-A-Jack-to-Fakra-B...4603df29e6
Any of these will do, dont worry about the length, the BT antenna is good to 7-10m around the antenna, so you can have it in the boot.
Post #176575 8th Mar 2013 12:52pm
Budgie
THIS is the genuine cable, although the ebay advert is from the U.S and not much help, but at least you can see what it looks like and maybe have a look around the BMW's in some local scrapyards to see if you can find one? Whistle
Post #176599 8th Mar 2013 2:22pm
comports
Arghh. Can't try the pairing yet as the button is in the boot (with my new loom) and the procedure is to hold the button for a few seconds, then while holding it, switch on the ignition and continue to hold for a couple of seconds.... My Mrs won't help me as it's still raining... Big Cry Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #176631 8th Mar 2013 4:39pm
ccfj1
Use the intravee if you have one mate.
Post #176632 8th Mar 2013 4:41pm
comports
Good shout John - Let me try it that way instead.! but may wait till I dry off a bit first. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #176633 8th Mar 2013 4:43pm
comports
Well - thanks to ccfj I have now installed my bluetooth on the FF. Routed all wires back to the boot for the mic and all is good.......
Apart from the fact that my mouth needs to be approx 2mm from the mic for the other person to hear me.!
Anyone come across this before..? I've ordered a new mic for tomorrow and hope that it will fix the problem but if anyone has any further info i would be grateful.
Thx Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #177736 15th Mar 2013 1:17pm
ccfj1
Make sure that the mic is in the correct way round mate, the arrow needs to point to the windscreen (I think).
Thx
If its not that then try swapping the pins in the mic plug, could be RR are the opposite of BMW!!
Post #177740 15th Mar 2013 1:39pm
comports
Thanks John.
Interestingly the mic does work and gives very good sound when its literally 2mm from my mouth. As soon as you move it to 3cm or so away the other person can't hear anything..!
Tried it all ways round in fact it was pulled towards me and not fixed in the overhead console.
I may switch the wires to see if it makes a difference
Thx Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #177742 15th Mar 2013 1:43pm
ccfj1
You could try the mic loom plugged direct into the mic too, see what that does.
Post #177744 15th Mar 2013 1:51pm
comports
OK Have tried mic straight into bluetooth unit without the extra mic loom and also tried switching the pins on the lead and no change. Person in the car can hear very well but person being called hears nothing except very close up to the mic.
Hopefully a new mic tomorrow will sort it.!
Thx Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #177746 15th Mar 2013 2:23pm
