Home > In Car Electronics (L322) > stereo & nav aftermarket replacement for vogue 2003
warnster
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Lots of discussions regarding this topic so apologies in advance but I'm struggling to find the definitive answer.
Can anyone point me in the right direction as the more related threads I read the more confused I get. If aftermarket can do the job which should I be looking at?
Post #176068 5th Mar 2013 10:28pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
From memory the sticking point was getting the DSP amp in the boot to turn on - I understand it is possible to do if you retain the original screen/head unit (stick it on the glovebox in place of the CD changer) and wire the new touchscreen in parallel with it.
Post #176088 5th Mar 2013 11:09pm
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I have just changed my system!
New double din headunit with sat nav, iPod etc!
Had to remove the original dsp, nav, amp, tuner.
And replaced all with after market! So much of a better quality system!
Full thread coming soon!!
Post #176330 7th Mar 2013 10:57am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
cant wait to read that one - did you lose the mpg/trip control though..? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #176331 7th Mar 2013 11:08am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
As Comports, I need to do something with my cack HSE setup, looking forward to the thread SATVC!
Post #176332 7th Mar 2013 11:15am
comports
FYI Mr Tee - Yours may be a bit simpler with the HSE as I don't think you will have the whole DSP setup Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #176333 7th Mar 2013 11:17am
warnster
Will be interested to read up about it. Out of interest how much approx did it set you back?
Post #176334 7th Mar 2013 11:21am
SATVC
Only thing I've lost over stock is the time, timers but still have mpg cons 1 & 2, (although to reset you need to disconnect the battery) to set analogue clock disconnect battery and refit at 12 exactly Wink
Price can vary depending on equipment used!
Will have a full tread when I can!!
Post #176335 7th Mar 2013 11:28am
