Home > In Car Electronics (L322) > stereo & nav aftermarket replacement for vogue 2003 |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
From memory the sticking point was getting the DSP amp in the boot to turn on - I understand it is possible to do if you retain the original screen/head unit (stick it on the glovebox in place of the CD changer) and wire the new touchscreen in parallel with it. |
5th Mar 2013 11:09pm |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 |
I have just changed my system!
7th Mar 2013 10:57am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
cant wait to read that one - did you lose the mpg/trip control though..? Ash
7th Mar 2013 11:08am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2649 |
As Comports, I need to do something with my cack HSE setup, looking forward to the thread SATVC! |
7th Mar 2013 11:15am |
FYI Mr Tee - Yours may be a bit simpler with the HSE as I don't think you will have the whole DSP setup Ash
7th Mar 2013 11:17am |
warnster Member Since: 26 Feb 2013 Location: south west Posts: 56 |
Will be interested to read up about it. Out of interest how much approx did it set you back? |
7th Mar 2013 11:21am |
Only thing I've lost over stock is the time, timers but still have mpg cons 1 & 2, (although to reset you need to disconnect the battery) to set analogue clock disconnect battery and refit at 12 exactly
7th Mar 2013 11:28am |
