Home > In Car Electronics (L322) > Wiring route from Engine Bay to Cabin?
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I'm gonna be hitting my new system soon!
Hopefully tomorrow all speakers, amp, dsp, screen etc will be removed and new cabling run!
Ill keep you posted on a good route if I find one??
Post #174720 26th Feb 2013 8:56pm
SATVC
I've run my amp cable!!
Just behind the battery (it will need removing) there is a massive grommet with the main power running through the bulkhead! Into the cabin, all I did was cut a small slit with a Stanley, fed the cable in and it popped down from behind the glove box!!
Running the cable to the boot was an all together bigger pain in my buttt seats and all trim panels etc have to be removed!
Post #174872 27th Feb 2013 6:53pm
at least you didnt have to take the glovebox out.. Thumbs Up ... - .- -.
Post #174874 27th Feb 2013 7:20pm
SATVC
That was quite a result. I popped the side panel of the dash (passenger side) and you can see where it comes through if it gets tangled! Ill try and get a pic tomoz!!
Post #174875 27th Feb 2013 7:24pm
The one on the right Thumbs Up
Post #174879 27th Feb 2013 7:30pm
SATVC
That's the one! I slit a hole at the bottom of that large grommet and happy days!!
Perfect pic!! Wink
Post #174880 27th Feb 2013 7:32pm
