Home > Technical (L322) > STEERING FROM HELL !!! |
K20FTY Member Since: 15 Nov 2011 Location: Derby Posts: 13 |
I have a similar problem - steering is really heavy at low speed - my indie reckons its either the servotronic valve, the electrics or the knuckle itself - seems like you're looking in all the right places. I've had a good look at the knuckle on mine & can see rust around the mating faces - I've drowned it in WD40 & will give it a few more soakings over the next few days & report back - if it makes a difference, I'll try to strip it down & clean completely & re-grease 2003 L322 Vogue SE 4.4 + LPG
8th Feb 2013 2:40pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
interesting, let us know how you get on [with pics if you can].. ... - .- -.
8th Feb 2013 2:55pm |
Update: had servotronic valve renewed by trustworthy indie (genuine brand new RR part) - no difference, steering still heavy at low speed. Changed BCM with one from a 'known good' donor vehicle - still no change...
21st Feb 2013 7:12pm |
It could be "upstream" of the steering housing and then the power steering does not make a difference. MY 2010 5.0 SC Galway green and sand interior!!
21st Feb 2013 7:32pm |
plumajp Member Since: 18 Jul 2013 Location: bridgend south wales Posts: 73 |
Did we ever get to the bottom of this?? |
22nd Jul 2013 8:32pm |
