Home > In Car Electronics (L322) > Sat Nav Power Light |
Saltyfish Member Since: 19 Jun 2012 Location: Yate/Bristol Posts: 22 |
Hi all
20th Feb 2013 9:00pm |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
When you say sat nav light
20th Feb 2013 10:14pm |
Many thanks for the reply's, the nav unit is a MK3 and the red power light on the cd drive stays on after the driver door has been shut. The car enters sleep mode (gear selector light off) but the nav drive power light stays on, hope this clarifies things.
21st Feb 2013 4:32am |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 208 |
are you noting the sat nav light being on by looking through tailgate glass with the parcel shelf folded forward and the cover removed when the car is asleep as this is the only way to see if it shuts down , because as soon as you open a door or unlock etc the sat nav will power up 1990 3.5 v8 defender
21st Feb 2013 5:59pm |
Yes KLF400 thats exactly how im checking it ive even made sure the drivers door is the last i shut. |
21st Feb 2013 8:11pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
I'll roll out the old favourite as a starter: battery disconnection procedure.
21st Feb 2013 8:19pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
You could just remove Fuse 49 and leave the car for a while.
21st Feb 2013 8:27pm |
Ok so ive unplugged the Sat Nav and everything appears to be fine, so its probably the Sat Nav not shutting down.
27th Feb 2013 4:21am |
