![]() | Home > For Sale & Wanted > Wanted Injector for a 2003 TD6 |
m90got Member Since: 18 Oct 2011 Location: scunthorpe Posts: 120 ![]() ![]() ![]() |
Has any one got an injector for sale? or can anyone recomend a supplier
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
genuine £262+VAT + £130 old unit surcharge
Cheers Dan ive just sent you a PM about this problem Current Stable:
My duff ones are going to go back to the exchanger i got them from if you want their details...
KingPleb any details will be welcome, its in at a garage so i would hope they have the tool to take them out thanks Current Stable:
Here you go fella |
What actually happended to your car for you to think that the injectors were on there way out
Simply would run rough after it started to get warm, then idle rough as well basically like a missing petrol. Then when warm just wouldn't start unless a quick blast of WD40 in the intake manifold, just enough to get the tick over up and then it was fine. Basically as the fuel got thinner with the heat the 6th injector would leak more fuel back to the tank and the rail couldn't keep the pressure up.
mine has been running lumpy on tick over the getting worse in top gear when you are light on the throttle,
Mine had
