![]() | Home > Maintenance & Mods (L322) > An upgraded dual battery idea. |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 ![]() ![]() ![]() |
Got one of these in mine and it is great. It has bought the battery voltage of the main battery up ever so slightly and I don't get the HDC inactive coming up when I start it now. The battery in the back will run a 39 litre Engel fridge for 3 days without ever needing to start the car, and I know it will start when I need it. You would be hard pressed to find a smarter relay than this, it is very well thought out. |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
I do like the idea of the DT90 (aussi relay), and the fact that you get a little juice out of the starter battery to suppliment the leasure batt. But that relay is not redily avalible in the uk.
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Hi again Barracuda, the DT90 has another advantage in that it not only allows any accessories to draw some of their power requirements from the cranking battery. Up to 50% of the cranking battery’s capacity can be used.
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
are you considering to modify your dt90 to also take an input charge of a solar panel, this then could cycle both batteries to optimum- even not used for a long time |
Hi Havank and while I am woking on a very basic 20 amp solar regulated input for the DT90, you would not need the DT90 if you used a solar panel no bigger than 10w.
Solar always tricky in the UK, seems like today is the first time I have seen the sun in months! |
Hi Joe and you need to be aware of the amount of energy your RR is using while it’s parked up.
Drivesafe,
daz87 Member Since: 09 Apr 2013 Location: London Posts: 1 ![]() |
Thanks for the advice, that's been really helpful. |
