Home > Maintenance & Mods (L322) > 2006 to 2010 conversion |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I think modification to wings was for preface lift cars only < 2005
12th Feb 2013 1:53pm |
Harvey123 Member Since: 24 Nov 2012 Location: london Posts: 95 |
Yes mate what i intended to do was strip the whole front in one go... But just wanted to double check with the wings.. Headlights shouldnt be a prob as i have a plug and play resistors for this.. My main worry was if i needed to cut the wings???
12th Feb 2013 2:01pm |
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 |
Are you selling your old parts? |
12th Feb 2013 2:09pm |
Yes as soon as the conversions done Range Rover Autobiography Black Conversion |
12th Feb 2013 2:15pm |
Message me how much you want and what you have and good luck with the conversion |
12th Feb 2013 2:16pm |
Ok will pm you with details once its completed
12th Feb 2013 2:17pm |
Harvey keep me posted please very interested in talking to you after completion. You should check lights in existing connections anyway as removal of existing is only 3 screws.
12th Feb 2013 2:50pm |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 |
Hi mate, hope all is well.
12th Feb 2013 5:18pm |
Fantastic cheers
12th Feb 2013 5:23pm |
Looking forward to it!
12th Feb 2013 5:38pm |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 |
be carefull with the wiring on the headlamps , allthough the headlamp plugs are the same on 2006 and 2010 the pins are wired different , you will have to re-pin the multi plug to suit the 2010 headlamp the pins come out easy with the correct tool , i do have the pin data that i saved from l322.com before the site went down if you need it 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
12th Feb 2013 7:05pm |
I used the same resistors on the back leds and they where very straight forward.. I have got the same resistor boxes for the front and an instruction manual showing me step by step..
12th Feb 2013 7:10pm |
