Home > Maintenance & Mods (L322) > 2006 to 2010 conversion
Harvey123
United Kingdom 2006 Range Rover Autobiography Td6 Java Black
I am really confused about this as some members have said you have to and some said you dont.
When converting a 2006 to the 2010 front end.. Is there any modifications required to the wings?? Or should the 2010 bumper fit straight on with the brackets??
Also does the 2010 fog/pdc wiring loom
Fit straight into the exisiting 2006 loom???
Thanks
Harvey Range Rover Autobiography Black Conversion
Post #171709 12th Feb 2013 1:55pm
Googsy
I think modification to wings was for preface lift cars only < 2005
From what I have read yes should plug straight in you still need a resistor inline to slow indicator flash.on earlier cars as above new loom was needed hope that helps. Thumbs Up
Can you not do a trial fit of light to existing loom so you will know for sure ?
Keep me posted as I plan to do this on my 2008 at some point. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #171720 12th Feb 2013 2:53pm
Harvey123
Yes mate what i intended to do was strip the whole front in one go... But just wanted to double check with the wings.. Headlights shouldnt be a prob as i have a plug and play resistors for this.. My main worry was if i needed to cut the wings???
Thanks
Looking to do my conversion at some point this week or next.. As long as this poxy weather holds out as im doing it all on my driveway Range Rover Autobiography Black Conversion
Post #171721 12th Feb 2013 3:01pm
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Are you selling your old parts?
Post #171722 12th Feb 2013 3:09pm
Harvey123
Yes as soon as the conversions done Range Rover Autobiography Black Conversion
Post #171723 12th Feb 2013 3:15pm
Durham4416
Message me how much you want and what you have and good luck with the conversion Smile
Post #171724 12th Feb 2013 3:16pm
Harvey123
Ok will pm you with details once its completed
Cheers Range Rover Autobiography Black Conversion
Post #171726 12th Feb 2013 3:17pm
Googsy
Harvey keep me posted please very interested in talking to you after completion. You should check lights in existing connections anyway as removal of existing is only 3 screws. Thumbs Up
I'm certain no wing mods are needed due to existing light being one piece as opposed to two pieces on older model hence reason for cutting wing. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #171742 12th Feb 2013 3:50pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi mate, hope all is well.
After extensive reading, no wing mods required for models 2005 onwards.
Post #171789 12th Feb 2013 6:18pm
Harvey123
Fantastic cheers
If weather is good then will be doing it this weekend and will send pics Range Rover Autobiography Black Conversion
Post #171792 12th Feb 2013 6:23pm
Stryke
Looking forward to it!
Fingers crossed for you. Thumbs Up
Post #171798 12th Feb 2013 6:38pm
klf400
Thanks
be carefull with the wiring on the headlamps , allthough the headlamp plugs are the same on 2006 and 2010 the pins are wired different , you will have to re-pin the multi plug to suit the 2010 headlamp the pins come out easy with the correct tool , i do have the pin data that i saved from l322.com before the site went down if you need it Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #171817 12th Feb 2013 8:05pm
Harvey123
I used the same resistors on the back leds and they where very straight forward.. I have got the same resistor boxes for the front and an instruction manual showing me step by step..
Post #171820 12th Feb 2013 8:10pm
