![]() | Home > Technical (L322) > Air Suspension - Extra modes Crawl & Extended ? |
CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82 ![]() ![]() ![]() |
I've searched both terms without coming up with a thread on it.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
this was talked about many moons ago , i cant remember what the result was..... have you tried the RRS procedure on yours? ... - .- -.
found a thread via search..
As per the thread it needs to sense its being grounded to go up.
robjp Member Since: 14 Jan 2013 Location: North Wales Posts: 104 ![]() ![]() ![]() |
For 'crawl' mode, you can select the 'Access' height and wait until it has set itself, press the centre button to lock, and then the suspension will stay in that height. I believe that going over 21 (or maybe 25) mph will cancel it anyway, and go back to 'normal' height, but would need to check the manual |
Thanks for the replies all.
Hi. According to everything I've read - and the owner's handbook, yes, access = crawl.
