Home > Technical (L322) > Remove centre console?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
post moved to a more appropriate section ... - .- -.
8th Feb 2013 7:30pm |
broncoupe Member Since: 21 Nov 2011 Location: bournemouth Posts: 70 |
Does anyone have a PDF file re removing the centre console
9th Feb 2013 1:54pm |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
This may help.
9th Feb 2013 6:49pm |
The RAVE will have all the info you need. You have a touch screen so later nav but you still have the early interior.
10th Feb 2013 11:37pm |
Thanks guys for your help pictures got me on the right track please note there are 2 hidden screws at the front edge where the centre console joins the heater panel.most other screws are reasonable obvious except the 2 under the storage box in the armrest, also removing the power socket in the box is a bit awkward .
12th Feb 2013 6:58am |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
I have started having some problems with what I think is the ignition switch.
5th Apr 2013 12:55pm |
5th Apr 2013 1:14pm |
Thanks I am actually in the new forest on holiday at the moment.
5th Apr 2013 1:24pm |
someone on the forum has actually done a 'push to start' switch modification, like the newer bmw's have.. ... - .- -.
5th Apr 2013 1:26pm |
Stan, it's a bypas to avoid a problem and keep me going! still have to use key. |
5th Apr 2013 1:29pm |
from memory this member still puts the key in but then pushes the start button..
5th Apr 2013 1:38pm |
found it..worth a read..
5th Apr 2013 1:44pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
I had the same problem... This part cured mine
It fixes to the bottom of the original barrel, so no re-programming or new keys needed If I remember correctly it was around £90 including VAT from my local L/R dealer, and fitting was a straight forward job :D Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
5th Apr 2013 3:10pm |
Johnte, many thanks. Do you remember what the part is called or its number. I asked the garage briefly yesterday pm and say it is not available/does not exist - they are still pointing me towards the full lock/key kit!.
6th Apr 2013 7:33am |
