Home > Technical (L322) > What are these plugs / related to satnav?
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
Located in the right side of the load area (2 to 5)
Seems like 4 is a GPS antenna link? What are the others?
My question, behind that, is overall, what parts I'm missing to add Satnav to my range, given I don't have a DVD player either, here's the other side, but I have the menu in the car. It just tells me "no sat nav fitted"
On this side I see not cables to connect the Satnav disc player (if it's supposed to be on that side).
Thanks! 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #170930 8th Feb 2013 11:44am
nbunney
Could be wrong, but 3 & 4 are for the remote for the FBH and 2 for towbar electrics.
I'm sure someone will be along to dis-prove me soon.
Sat Nav does go on the LHS, where you have a gap.
Post #170964 8th Feb 2013 3:07pm
Ibartsimp
Hi, any confirmations on this? Are your sure for 4? Looked like a coaxial cable (to the roof antenna ?)
BTW, one question: Is the roof antenna only used for GPS or also for telephony? 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #175103 1st Mar 2013 8:01am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Hi
The unit would be in the cradle under the Nokia Phone module in the nearside electronic compartment.
So it's either never been fitted or removed. There should be some associated wiring harness. I am not in my car so cant check if it would have a fiber optic connection to. Mine was a blue one! Smile
Post #175175 1st Mar 2013 12:00pm
