Home > Technical (L322) > Possible Injector Failure
Page 1 of 4 1234>
Well for some reason my FF has decided its not getting enough mechanical attention.
This morning on the way to an office once the engine had reached a certain heat, engine performance dropped like a rock so much so I could floor it but get very little power. I thought this might be turbo related but letting off I get the tell tale noise of a wastegate opening. Now when I stopped at the services for a minute and went to restart it took about 4-5seconds and then caught and did the same about 20minutes later when I got to a local shop. Once started it is a little rough to idle like it misses occasionally and again performance is Censored
Now I'm thinking that i either have air being sucked into the Fuel Supply System when a pipe gets soft enough that a tiny crack becomes flexible enough to open up.
OR
An injector is failing/Failed...
Now I have a load of fuel line at home and although its not clear would do to replace some leak off pipes which is where I think I'll start and then the fuel filter to HP Pump feed pipe.
To do the HP feed pipe I'm guessing i need to remove the air filter box cover, and the engine top cover as well as i can see it vanish under the passenger side of the engine top cover Sad
I have a 50/50 BioD/Diesel mix at the moment so I doubt its the fuel being too thick as it would be the opposite and wouldn't affect performance.
Anyone any input on related issues in their experience? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170651 7th Feb 2013 10:02am
i'm guessing an injector failure would result in a lumpy engine which i dont think you're getting, i would go with the your fuel starvation or air in system theory... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #170654 7th Feb 2013 10:10am
A lovely way to spend a saturday Sad
And there was me hoping to do a new filter and cook my lights Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170684 7th Feb 2013 1:22pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Remember - common rail - check that the electrical connectors to the injectors are all good, before condemning one.
Can you check for fault codes?
Post #170763 7th Feb 2013 5:34pm
Haven't got a fault code reader. Its really bad once the engine is warm and low and behold I had to stop the engine a few minutes ago when warm and now it won't catch when cranking. It was idling rough just as I pulled in and down on power for the last few miles so its gotta be air in the system as even if two injectors were dead it would still run but like a dog Sad
Guess I now need to wait for it to cool down! Not good when I need to be 30miles away for 1800hrs in traffic! Can't keep a woman waiting can you! Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170764 7th Feb 2013 5:37pm
good luck on the journey Will.. Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #170765 7th Feb 2013 5:38pm
Simes
Always happens when you're on a promise!
Post #170766 7th Feb 2013 5:39pm
Think ill need it. Have a nice sucking sound coming from the engine bay so just trying some priming runs now Big Cry FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170767 7th Feb 2013 5:41pm
Well i gave up in the end and left it a few hours.
Went back about 30 mins ago and with an extra few jump start volts started after hardly any cranking.
Got to be a pipe somewhere as cant see how an injector would go faulty when warm and how it wouldn't throw up a warning light either Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170856 7th Feb 2013 11:14pm
Well it was fine this morning for about 20mins then started again. it held speed fine at 60 for a good 30mins later and some light driving at about 30 and then just died Sad
So got it recovered to work where i'll look at it tonight in the dark Smile
I'm hoping after a boost it will start fine, if not i'll get it dragged home and look over the pipes but the guy that turned up said it really needs the inlet plenum taking off and checking around there but there is no air in the fuel upto the fuel filter and the clear section beyond it, confirming what i think of leak off pipe or something towards the Injection pump could be weeping.
There seems to be a few diverter valves in the system and i'm wondering if one of these is the issue Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170934 8th Feb 2013 12:58pm
Your wasting your efforts. Get to an Indy/Stealer and get the codes read these cars are very clever IT WILL tell you what the problem is.
Otherwise pop to Halfords buy a cheap code reader or you may just F-up stuff that is not broken..... Surprised
PS: The Chip Fat may not be helping long term.
Post #170937 8th Feb 2013 1:31pm
Problem is gaz i get no warning lights whatsoever so not sure anything will show up on a FC reader unless its a good one like autologic/sdd/FSC-MSV as to see what pressures are being seen by the sensors Sad
Its very strange as i'd expect the engine light to be on but its not... Have i just got a vehicle that doesn't want to warn of faults and just lets them happen....
PS its running 50-50 at the minute so shouldn't be having any undue effects on the system as i've tested it to contain no meth and no soaps so far as i test each batch before i use it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170938 8th Feb 2013 1:33pm
Only OBD-2 Codes will throw the MIL on all the other "Many" codes are stored without a light. Thats why I suggest a trip to a Land Rover Equipped Indy or a Stealer. Testbook can even tell you which parking sensor is faulty let alone diagnose a fault that's stopped the engine working properly. I really think its the way forward to get a quick & safe solution...
Post #170939 8th Feb 2013 1:36pm
Wish i had bought that £300 msv when i had the chance now Sad
Cheers Gaz, I'm just sounding out one now that i think has a testbook and doesn't charge £80 to turn it on Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170941 8th Feb 2013 1:37pm
Also less than perfect BIODIESEL can/will leave some very nasty residue that will clog lots of fuel/injector parts....
Post #170942 8th Feb 2013 1:39pm
Page 1 of 4 1234>
