Home > Technical (L322) > drivers side washer stopped
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
hi guys, my drivers side washer has stopped working, Question Question i have cleaned the jets with a pin several times, and pulled the supply tube off which has plenty of water and pressure but still nothing comes our Banging Head
any idea's as to what could be the problem as im a bit confused. all i can think of is that the jet/s must still be blocked,
also what are the electrical connections for to each jet Question Question , as i thought the only power would be going to the pump Question Question . or are they for something else Embarassed Embarassed
bob
Post #170360 5th Feb 2013 9:38pm
Dont know for sure, but think that the washer jets are actually a valve, yhat might be what the wires are for. The pump pressurises the system and the valves then open and let out the water. Sounds like the valve is bust. Try swapping them round. There is nothing that can't be fixed with a hammer😜😜
Post #170379 5th Feb 2013 10:19pm
BOBCUSSEN
thanks for that, i will swap them over and see what happens Question looks like another order from dan Exclamation but i doubt they are not expensive Question
bob
Post #170383 5th Feb 2013 10:25pm
Happened to me a few weeks back done the pin thing and pulled the hose off water getting through okay , time to get a new washer jet from Dan at Duckworth's , 5 min job to change . ====================================
Post #170385 5th Feb 2013 10:28pm
£8 inc Vat from Dan Thumbs Up ====================================
Post #170388 5th Feb 2013 10:29pm
BOBCUSSEN
thanks joker, will place an order for both of em.
kind regards
bob
Post #170391 5th Feb 2013 10:31pm
